fuel pump
fuel pump
Postby 92d250 » Sat Dec 06, 2008 8:27 pm
well im getting a fuel pump tomarrow and i am wondering what psi to regulate it at? and should i keep the lift pump in?
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby gear jammer 91" » Sat Dec 06, 2008 10:48 pm
15psi is about the max you want to put into our injection pumps. Much more and you run the risk of blowing the front seal out. If your are running an aftermarket lift pump, you don't need to continue to run your stock one.
01 LB7
gear jammer 91"
Postby GO OVRIT » Sun Dec 07, 2008 6:32 am
It depends on which pump you are getting. What kind of performance numbers will it do? Are you dead head or bypass regulating it?
GO OVRIT
