how much air do they move?????
Postby DTanklage » Fri Dec 12, 2008 2:01 pm
https://www.shopatron.com/product/part_number=1047015/532.0.19175.20189.2096.0.0
how much fregin air can these motors move?
how can they move enough to spin that thing?
darn
DTanklage
Postby 1991cummins » Fri Dec 12, 2008 4:06 pm
id like to know what size the stock housing is??? cause that is huge :shock:
1991cummins
Postby Richie O » Fri Dec 12, 2008 5:08 pm
Well they are about 70 or so cubic inches bigger then the 5.9. and they turn ( if I remember correctly ) 3500 rpm's stock. Its been a while since I drove one.
Postby KTA » Sat Dec 13, 2008 7:25 am
Also note that those are garret size ratings and as such they give compresser back wall instead of inducer size.
