I remember sayin "I dont need any grid heaters"
Postby RSWORDS » Mon Dec 22, 2008 7:36 pm
That was about the time I was making the new cross over for teh turbo
http://www.dieselbombers.com/show-tell/ ... video.html
How I take that back! :D
RSWORDS
Postby Richie O » Mon Dec 22, 2008 7:41 pm
It started.. I am used to that. My big 3406 cats smoke and buck too. My triaxle will black out the neighborhood when its cold. I have to start it and leave the area or I would surely die. :lol:
Postby cummins king » Mon Dec 22, 2008 8:01 pm
Are you a pansy?
Step on the fuel and keep cranking till it starts. Even with no grid heaters or KSB mine will start on first crank
93 4X4 auto
cummins king
Postby RSWORDS » Mon Dec 22, 2008 8:09 pm
cummins king wrote:Are you a pansy?
I'll try that tommorow!
Oh and a tad grumpy today are we? :lol:
RSWORDS
Postby cummins king » Wed Dec 24, 2008 2:37 pm
Ya sorry, i was up 36 hours plowing, and i dont even know why i went on here instead of going to bed. devotion, i guess, lol
93 4X4 auto
cummins king
Postby Richie O » Wed Dec 24, 2008 2:52 pm
O those were the days. I used to pull 36 hour shifts in a 7 yard plow truck. It did have power steering but was a standard. The old clutch leg got pretty tired. After a while you just turn into a robot and your eyes look like this :shock:
Postby cummins king » Wed Dec 24, 2008 11:42 pm
ya that's it,
93 4X4 auto
cummins king
Postby Begle1 » Thu Dec 25, 2008 6:01 pm
How much more cylinder washing are you looking at without the grid heaters?
Typically the heaters are only on for a few seconds before being off for a few seconds, so I would think that you're only looking at a most twice as much wash as without it. Which would mean that you're never going to see any more wear than typical.
Right?
Postby Ace » Fri Dec 26, 2008 8:10 am
Begle, it sounds to me like you're more worried about what would be a fuel dilution issue. Cylinder wash happens when the engine is left idling cold. Then you have incomplete combution leaving fuel in the cylinders under the stress of a running engine.
Just cranking it isn't going to hurt anything, unless you are talking about a lot of cranking to the point where raw fuel is left running down into the crankcase, diluting the oil.
Postby Begle1 » Sat Dec 27, 2008 11:08 pm
My understanding is that wash is when the fuel condenses onto the cylinder walls whenever RPM is low enough and the air is cold enough. The result is fuel diluting the oil and a lack of cylinder wall lubrication. Wash doesn't get any more likely with time, it just gets more damaging with time as more and more fuel builds up.
But I don't think the grid heaters would prevent that anyways; they might prevent it for the 5 seconds they're on, then not for the 5 seconds they're off.
Maybe the 5 seconds they're on is enough to clear the fuel that condensed during the 5 seconds they're weren't on?
A high idle would probably be more effective than grid heaters anyways?
Cylinder wash gremlins are as trumped up as ULSD gremlins, ATF gremlins and turbo cool down gremlins... But I'm willing to bet that some engineer behind the implementation of the grid heaters would think twice about their removal for reasons beyond emissions.
I seriously doubt it'd ever manifest into a problem.
Postby PapeCAT » Sun Dec 28, 2008 12:57 am
yeah Rswords, do you have a fuel pressure gauge? What do you have in there for a lift pump? Even without grid heaters your truck should start up easier........................................
PapeCAT
Postby RSWORDS » Sun Dec 28, 2008 1:36 pm
Fuel pressure is the pretty standard 4-5 psi for teh stock set-up. It usually starts no problem but it was sitting for about a week with a good wind blwing straight into the grill and about 17* outside.
RSWORDS
