Factory Tach On A '91.5
Postby peobryant » Wed Sep 10, 2008 7:47 pm
Does anybody know if a factory tach will work on '91.5 intercooled Cummins? I know they don't just plug right in, but I have been told that people have even put the tachs in non I/C trucks, so does anybody know how I would get on to work on my truck?
Postby peobryant » Fri Dec 26, 2008 10:36 pm
Anyone...? :cry:
Postby Philip » Fri Dec 26, 2008 11:08 pm
Your going to need to install a sensor to trigger the tach. The 91.5"s didn't have a crank position sensor.
If you use a stock tach you will need it to be a 5 volt signal also.
If you go with an after market tach then it would need a 12 volt signal. Going with the 12 volt signal would let you use any auto tach.
Postby peobryant » Sat Dec 27, 2008 5:43 am
Is it possible to install a crank position sensor on my truck? What would I have to do? I realize it would probably be easier to use an aftermarket one, but I love the look of the factory ones.
Thanks
Postby Philip » Sat Dec 27, 2008 7:34 am
You could install a crank sensor. You would need a sensor. An aftermarket magnetic type would be your best choice. Then glue a couple of magnets to the harmonic balencer. Then you could tap into the 5 volt circuit from the PCM. All your gages use 5 volts for their power source.
Postby RumbleFish » Sat Dec 27, 2008 11:09 am
yes, it is entirely possible. my 91.0 (still kicking myself for getting rid of this one) had one in it when i got it. it had the crank position sensor and everything.
Postby peobryant » Sat Dec 27, 2008 1:11 pm
Where would get a crank position sensor? Also, I'm not eletrically inclined, so how hard would one be to install?
Thanks again,
Postby Richie O » Sat Dec 27, 2008 9:07 pm
Don't you also need a different balencer. My 93 has a square recessed chunk missing. My 89 does not.
Postby 921stgen » Sat Dec 27, 2008 9:43 pm
Isspro makes a couple of tach sensors.
91 W250 pods, , pull cable, Isspro FP gauge, Isspro boost, pyro, 366 spring, 91 W350, sold-92 W250, 40 hp Injectors, Bully Dog Fuel Pin, Isspro-tach, boots, pyro, AM electric fp gauge, 3200 GS, 5" AEM intake, 4" exhaust 5" stack
921stgen
Postby Richie O » Sat Dec 27, 2008 10:31 pm
921stgen wrote:Isspro makes a couple of tach sensors.
I have the R8912 sensor on my 89.
Postby Richie O » Sat Dec 27, 2008 10:33 pm
Richie O wrote:Don't you also need a different balencer. My 93 has a square recessed chunk missing. My 89 does not.
I thought you guys were talking about putting a factory unit on.
Postby peobryant » Wed Dec 31, 2008 12:14 am
I want to put on a factory tach, but still need more info.
I know Isspro makes sensors, but will they work for the factory tach?
Postby Richie O » Wed Dec 31, 2008 10:01 am
Well it works in reverse. A isspro will work off a factory tach harness. So maybe it will work that way also. I would call isspro and ask for a tech guy. They have always been good to me and have gone out of there way to help me.
Postby peobryant » Wed Dec 31, 2008 3:03 pm
Thanks Richie, I'll give them a call.
Return to Electrical
