what dually rims will work?
Postby U.S MMA » Wed Dec 17, 2008 6:31 pm
Im looking to finish my swap with some front spacers. I know that the rims on my d70 have a designated inner and an outer, that fit together only one way. Id like to get rims that i can swap all the way around, for tire life, but do duallys work like that? As it is now, i would need 3 spares, which for obvious reasons isn't going to work. School me on the coined and flat lugs? what do I need? thanks men.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
Postby U.S MMA » Thu Dec 25, 2008 11:40 am
come on, I know out of 53 views, at least a couple of you guys have something to say. I don't know sthi about the rims, and i need to go to the junk yard.
U.S MMA
Postby randyswelding » Thu Dec 25, 2008 8:17 pm
howdy,are you runnin fancy(alumineum)wheels?or are you still factory?thats the first question.coin faced wheels are hud centering and you can go inside out with those just ,make sure the alingment pin is in its hole if you still have it,just make sure the droped coin goes into the raised coin.let me know if you need any more help ill try to help ya :D
randyswelding
Postby peobryant » Sat Dec 27, 2008 1:28 pm
I don't know much about this topic myself, but yu might be better off finding a set of wheels you like, then post and ask if they will work for your truck. Dually wheels are a apin to shop for if you don't know what to look for, (and I don't.)
Postby U.S MMA » Tue Dec 30, 2008 8:40 pm
Randy I have an aluminum outer and steel inner. I just got tires and the guy at the shop told me the rims fit together only one way. Is that what you mean by alignment pin? I need to call some of these companies that make dually adapters and find out what rims they are specified for. Im hoping they will match my d70. If right now I could just find a dual rim that would work as a spare, im driving to alaska in april and would like a spare tire.
U.S MMA
