16 or 30 psi fuel pressure gauge?
Postby dpuckett » Sun Dec 28, 2008 10:29 pm
I have a piston pump on my pickup, and am looking at getting another Westach fuel pressure gauge (another, as in "I had one on my last pickup, and I'd like another one on this truck"). I recall Philip saying that most electric gauges like to be in the middle of their range. Since the psiton pump typically puts out 15-16psi, that leads me to believe that I need the 30psi, but would it be overkill?
Daniel
Postby KRB64 » Mon Dec 29, 2008 4:37 am
I'd like to add a Westach fuel pressure guage too. How did you install it on your old truck? What all is involved?
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby dpuckett » Mon Dec 29, 2008 9:34 am
I installed a 1/8NPT- 1/4" barb adaptor on the post-filter banjo bolt. I found a good mounting spot (zip tie to the cruise vacuum line) for the sender, and ran a fuel line from the outlet to the sender (about a foot, maybe 18"). Hooked up my electrical wires, and was good to go.
DP
Postby bgilbert » Mon Dec 29, 2008 10:52 am
I have the 30psi Westach electric gauge, no complaints. Pay it forward many years ago 8) 8) 8) .
Bill Gilbert
Postby PapeCAT » Mon Dec 29, 2008 4:08 pm
I'd like to Nomiate bgilbert as the Crown King of Pay it Forward Columns! Remember when I paid that A pillar gauge pod Fwd to you Bill? :o
PapeCAT
Postby KRB64 » Tue Dec 30, 2008 5:19 am
PapeCAT wrote:I'd like to Nomiate bgilbert as the Crown King of Pay it Forward Columns! Remember when I paid that A pillar gauge pod Fwd to you Bill? :o
Um, how does "pay it forward" work? :oops: Free items except for shipping or what??? I see the columns but no explanation... :?
KRB64
Postby PapeCAT » Tue Dec 30, 2008 1:48 pm
Excerpt From TDR:
"Over time there have been a number of instances where members have offered parts for free with the only request being that you "pay it forward" and do the same when you get something available. We're going to try this for 90 days and see if there is enough demand for this forum. We thought the best format for this would be to have it here in the forums rather than in the classifieds. ONLY items for free are ok to post here and only from individuals - no vendor items allowed. Getting paid for your shipping costs are ok."
PapeCAT
Postby randyswelding » Tue Dec 30, 2008 6:40 pm
dang bill you got alot of pay it fowards,that was a nice dana 60 axle and thanks for gettin me home,now back to the post where do mechanical gauges like to be?in the middle like electrical gauges
randyswelding
Postby PToombs » Wed Dec 31, 2008 6:47 pm
Yes, you should generally always be in the middle of the working area of the guage for best results.
