Parking and Anti-Lock light stay on
Postby peobryant » Wed Dec 31, 2008 6:15 pm
Went to start my truck up a couple hours ago to take my girlfriend home, and noticed my Parking brake warning light, and Anti-Lock light on the message center stayed on the whole drive. What could be the cause of this? This is the first time it has ever happened, and it is pretty annoying.
Thanks for any help.
Postby Richie O » Wed Dec 31, 2008 6:26 pm
If you had her stay the night that would not have happened :lol: . My 89 has been that way since I put in my replacement rear end a few years ago. Have not looked into it. I am going to rip out the abs box just like I did on my 93.
Postby KTA » Wed Dec 31, 2008 6:45 pm
I find that typically my lights come on when I have a vaccum leak somewhere. There is a sensor beside the brake booster that measures vac and if it is low those lights will come on. A bad sensor in the rear diff can cause it too.
Postby peobryant » Wed Dec 31, 2008 6:54 pm
Thats how it usually works right, Richie? :lol:
Thanks for the info. Brian, I'll look into that.
Postby peobryant » Thu Jan 01, 2009 11:28 pm
Any more info. on this brake booster? Where is it located, and what would I have to do to test it? Also, where is the sensor located in the rear diff?
Thanks
Postby PToombs » Fri Jan 02, 2009 7:56 am
Sensor on the rear diff is right on top, front side. The one for the vacuum is on the drivers fender, behind the hood hinge, towards the firewall. Follow the small line from the brake booster to the fender. See it? :shock: This one you can jump across to test.
Postby dpuckett » Fri Jan 02, 2009 10:28 pm
When the RWAL/ABS light comes on, the BRAKE light comes on with it, warning that you have a "problem" with the brake system. Normally, it is just an isue with the ABS- you're better off unplugging the controller box, and bypassing the hydraulic dump valve on the left rear frame rail. No more light, have to relearn to drive it with good brakes. If you have one of the six that came off the line with good brakes and ABS intact, just unplug the controller and the light will go out.
WHen you replaced the rear axle, you likely didnt plug the diff sensor back in, making for the lights come on.
Daniel
Return to Electrical
