hard start to no start
Postby coram » Mon Jan 05, 2009 6:32 pm
first, i've been reading this site for bout a week, great stuff. Now the problem, truck started with a slow drag a week ago, lost regulator, replaced.Charged battery, then day later done same dragin start, changed ground cable, still bad start, then tonite, no start. just click click. battery checks at 12.56 volts. HELP
coram
Postby Richie O » Mon Jan 05, 2009 6:36 pm
Have you load tested the battery? Sometimes they will have 12 volts just with no punch.
Postby coram » Mon Jan 05, 2009 6:40 pm
going to grab one tommorrow, one of the clicks is ac compressor clutch, this normal?
coram
Postby Richie O » Mon Jan 05, 2009 7:04 pm
Not sure. Does it start fine if you charge the battery?? I mean does it crank right over?
Postby coram » Mon Jan 05, 2009 7:54 pm
just got thru giving the starter a GENTLE tap with a brass hammer, fired up like a new cummins! thanks for taking time for me richie o.
coram
Postby Richie O » Mon Jan 05, 2009 7:56 pm
NO problem. Sounds like your starter is on the way out.
Postby coram » Mon Jan 05, 2009 8:10 pm
yep, got a local machine shop does repairs for diesel outfits, dialing his # rite now, hey thanks again
coram
Return to Electrical
