steering a little sloppy
Postby colodriller » Tue Jan 06, 2009 11:37 am
my pickup likes to follow grooves in the road, hit a little bump wants to follow it. slight curves to the right from 55-65 mph, it has a slight jerk in the steering wheel (kinda like turning in 4x4 at low speed). To the left it handles great. drives shaft maybe a little loose, can I adjust it? It does'nt seem loose enough to cause this though. Thanks
colodriller
Postby burnt_servo » Tue Jan 06, 2009 2:33 pm
what kind of shape is your steering shaft , drag link and tie rod ends in ?
'93 w250 .... stock ...
burnt_servo
Postby colodriller » Wed Jan 07, 2009 7:12 pm
I meant steering shaft is a little loose, not drive shaft shaft. Tie rod ends feel good. Just does'nt feel like theres enough play in the shaft to make it do what it's doing.
colodriller
Postby U.S MMA » Wed Jan 07, 2009 10:43 pm
steering shaft, or maybe a steering stabilizer might help a little. kingpin bushing and spring , bad steer tires, make a little check list and start going through it.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
U.S MMA
Postby A_port93 » Tue Jan 13, 2009 10:08 pm
i dont know if your truck is 4wd or 2wd but either way it is more than likely worn ball joints if it is a 4wd truck it could be your drag link as well. also look at your steering shaft to see how much is lost in the transfer from the shaft to the pitman arm.if you inspect your ball joints in your steering system for excessive movement and your shaft is pretty tight it might be time to dive into rebuilding the knuckles
93 w250 getrag 220k 60/12wg over an ht3b/26 and ddp sticks, south bend ofe
A_port93
