Speedo prob??
Speedo prob??
Postby ccoxva » Thu Jan 29, 2009 7:33 pm
My 91 has started doing something weird. You can sit in park and tap the fuel and the speedo jumps to 50 or 60 and goes haywire. Since this it does the same goin down the road at any speed. The odometer and trip quit working when this problem started also. Any suggestions?
Thanks.
1991 N/I 250
ccoxva
Postby KTA » Thu Jan 29, 2009 8:44 pm
Bad alternator intermitently going to ground?
Postby GO OVRIT » Thu Jan 29, 2009 10:28 pm
Is anything else affected? Headlights dimming? Stereo static? Volt gauge jump? If so, KTA is probably right.
GO OVRIT
Postby ccoxva » Fri Jan 30, 2009 3:05 pm
Everything else is 100% normal. ? Is the guage itself grounded to the dash frame?
1991 N/I 250
ccoxva
Postby ccoxva » Sun Feb 01, 2009 4:35 pm
1991 N/I 250
ccoxva
Postby 1991cummins » Sun Feb 01, 2009 9:07 pm
i have had the exact same problem... i have come to the conclusion that its the wiring, cause i have checked everything else... i have replaced the guage (which was also broken) and the probe (which i cracked upon reinstallation)... so i know its got to be a bad connector/connection or wire... so when i put the new clutch in ill let you know, if you havent figured it out by then :lol: ;)
Derek
1991cummins
Postby Richie O » Sun Feb 01, 2009 9:27 pm
I know if I have issues with my 93's speedo the vss crap will be coming out and a 89 or lower speedo head will be going in with a cable. :evil:
Postby ccoxva » Mon Feb 02, 2009 5:30 am
Narrowed down the prob. Got ill, got under the truck unplugged the sensor blew it out and turned the sensor about 3 times clockwise one or the other made it stop jumping and acting weird but the odometer still dont work. :?
1991 N/I 250
ccoxva
Postby 1991cummins » Mon Feb 02, 2009 6:22 pm
haha, is it a bad thing that your odometer works?? :lol: dont wana put miles on the truck :? but yah wana drive it! 8) 8) haha,
hmmm... well, i dont know that thats my problem though... its frustrating me :?
1991cummins
Return to Electrical
