Leaking i/p
Leaking i/p
Postby ccoxva » Sun Feb 22, 2009 2:23 pm
Has anyone else had the overflow on the afc housing leak after turning up fuel and ol smokey install?? A steady stream and Put the stock one in and it stopped leaking?
1991 N/I 250
ccoxva
Postby 1dumrednek » Mon Feb 23, 2009 11:49 am
no but about 2 months after i turned the fuel screw in 2 1/2 turns the top of the husing split and spayed fuel everywhere. no clue how that happened
A.J.
91.5 Power Ram w250 LE 5spd reg cab... totalled... again
2002 2500 laramie slt plus sport, nv5600, MBRP 4" straight pipe, edge juice w/ attitude, DC1 rims, kelly fierce attitude M/T
1dumrednek
Postby KTA » Mon Feb 23, 2009 4:23 pm
I have seen aftermarket and stock ground pins that allowed too much travel and resulted in a fuel leak around the afc pin.
Postby ccoxva » Tue Feb 24, 2009 12:17 pm
I have ran the pin before but its never leaked till I turned the fuel screw a little?? It was leaking out that hole like there was no resistance on it at all.
1991 N/I 250
ccoxva
Postby ccoxva » Tue Sep 22, 2009 12:22 pm
Updating my old post. I had put earlier that the leak stopped when the factory pin was reinstalled. Its leaking again. Does anyone know what seal/o-ring could be causing this. I was thinking that the little rod that rides on the fuel pin has a o-ring but cant remember. Looking down through the top of the pump that rod dont move anymore when you open up the fuel linkage.????
1991 N/I 250
ccoxva
Postby gear jammer 91" » Fri Sep 25, 2009 8:06 pm
There is an O-ring on that little rod, and it needs replaced. It's not that hard to do if you've had your pump top off before. The hardest part for me was getting the two little pressed in ball bearings out so I could get the afc lever out of the way, and get to the o-ring.
01 LB7
gear jammer 91"
Postby ccoxva » Thu Oct 01, 2009 6:06 am
Thats what I wanted to hear!!! THANKS for the reply..Need to do my gov spring anyway...
1991 N/I 250
ccoxva
