Looking for a new turbo 62/71/14 or 64/71/14?
Postby RSWORDS » Tue Feb 24, 2009 4:26 pm
KTA wrote:Buy it and try it. Hell the manifold is worth $300 so you could always resell the turbo and upgrade in the future if it isn't enough. The 71mm is really for the 400rwhp and up croud, anything less will probably be better with the smaller turbine.
I think thats what I'll do...
You say the 71 is for teh 400 up guys. IS the 65 gonna suck at my 400-425 goal? I'm not really worried about towing or anything.. just a pulling truck
RSWORDS
Postby KTA » Tue Feb 24, 2009 4:29 pm
With your POD injectors I don't think that is going to be an issue.
Postby RSWORDS » Tue Feb 24, 2009 6:13 pm
KTA wrote:With your POD injectors I don't think that is going to be an issue.
They aint staying for long... :lol:
Got them before I knew better. Gonna have some 6x16's on they way soon.
RSWORDS
Postby GLHS » Tue Feb 24, 2009 10:49 pm
BUY IT!
GLHS
Postby SChandler » Wed Feb 25, 2009 10:01 am
Buy it and run it and see how you like it. If you need a little more later on, places like High Tech Turbo can upgrade the turbo for you with the larger turbine wheels and housings.
SChandler
Postby Horus » Wed Feb 25, 2009 1:12 pm
KTA wrote:I made 480+rwhp and 1100tq with a 62-71 .80ar gated to 50psi with a 12mm pump head and a stock cam. That turbo is now my high pressure turbo in my twins setup. That was the setup in this dyno vid http://www.youtube.com/watch?v=tUzqDyXK87U
Did I see a picture of this truck in a diesel magazine recently?
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
Postby peobryant » Wed Feb 25, 2009 1:55 pm
Yep, it belongs to Brian Block (KTA) the 1st Gen master. 8)
Postby fergavs » Thu Feb 26, 2009 8:04 pm
I have tried many setups on my duallie but have almost no dyno sheets to prove them. 2 years ago I dynoed with stock cam, pods, maxed 12mm pump, piston lp, 57mm S300, ported head, 47rh auto, and made 337rwhp. Since then I added a bunch of other stuff (see sig) and the cam really seemed to help out. I can't coment on the cam change only because so many things were done at once but the cam makes a difference on the top end for sure. As a 64/71/14 S300 owner I would recommend going with the 62/71/14 because of its ability to work well as a part of the twins. I wish that's what I had done. Oh well that's why I got more then one 1st gen, hand me downs. LOL.
fergavs
Postby RSWORDS » Thu Feb 26, 2009 8:40 pm
How much difference will I see in running a silver bullet compared to a Super Phat Shaft. The bullet is a 62/74/14 and teh phat shaft is a 62/71/14
Gonna be a whole lot slower to spool? I am sure it will be slower but by how much is the question.
Thanks
RSWORDS
Postby peobryant » Thu Feb 26, 2009 9:05 pm
RSWORDS wrote:How much difference will I see in running a silver bullet compared to a Super Phat Shaft. The bullet is a 62/74/14 and teh phat shaft is a 62/71/14
Thanks
Whats the price difference between the 62/71 and the 62/74? The 62/74 will spool slower, but I would but the cheaper turbo, because it won't be that big of a difference. Ideally, I would go with the 62/71/14.
Postby fergavs » Fri Feb 27, 2009 6:57 pm
I would recommend that you purchase the 62/71/14. The 74 wheel im pretty sure will surge a little in the lower rpm especially when pulling heavy. The larger turbine wheel will also create more lag and Im not positive but pretty sure the 71mm is a better choice for the twins in the future as well.
fergavs
Users browsing this forum: No registered users and 508 guests
