Ramrod90 wrote:Right on thank you so much. Ever since I got my first gen, I have been told that we can't run 5" pipes past that tranny mount. Ill probably just put a little dent in the pipe right there so I don't get any knocking.
Ramrod90 wrote:Well I just figured if the outlet of the turbo is 5" and it will taper into 6" stack why add the restriction. Plus, it will sound a little deeper and louder turbo. JMO
bgilbert wrote:
For oil filter clearance, a tip kta told me, just angle the s400 away from the block and oil filter. There's no reason to mount the s400 parallel to the block.
To help get 5" past the t-case, I removed the top transmission crossmember support. A ton of room will be had with it out of the way.
