lectro_static wrote:Hi,
Im new here, have read alot of posts but still am unsure. I am going to get injectors for my truck, a fuel pin and a bit later upgrade the turbo. I am after 300hp or so. I do daily drive this and will haul a camper and trailer with my baja, sandrail and quad.
What would the best way for me to go be? I want to be able to blot out the sun but do not want to billow smoke when Im just driving. This leads me to another question, what do you guys think of adding a couple VW cold start injectors to the intake on a toggle switch so when I want to roll the coal I can but normally wouldnt. Would be kinda interesting but I would be a bit worries about the amount of extra fuel Id be dumping in when the switch is on.
I have my boost and pyro gauge on the way now and when I put those in this weekend I will be doing 4" exhaust at the same time. I have the full power screw up to the collar and the star wheel is about 120* and fine smoke adjust is up 3 turns. What are safe EGTs? The same as a gas motor or less?
Thanks in advance for any and all advice given
Mike
Richie O wrote:Its all personal preference. I don't like running hot for more then a few seconds. Thats just me. I don't like to take chances when it costs a fortune to fix the engines.
'91 Cummins wrote:Richie O wrote:Its all personal preference. I don't like running hot for more then a few seconds. Thats just me. I don't like to take chances when it costs a fortune to fix the engines.
I agree with you. I don't like to see anything over 1200*, and I don't even like seeing 1200* for more than a few seconds.
Pulltilbroke, is you puller also you daily driver?
pulltilbroke wrote:'91 Cummins wrote:Richie O wrote:Its all personal preference. I don't like running hot for more then a few seconds. Thats just me. I don't like to take chances when it costs a fortune to fix the engines.
Yep, sure is. I drive it everyday of the week, even during the pullin season(unless it's broke)
pulltilbroke wrote:Yep, 12mm 300,XXX mile pump thats never been off the truck
pulltilbroke wrote:Yeah, thats the plan after I find another DD
I got one found local but its a slushbox truck, but it does run great and is in decent shape
