1st Dyno run
1st Dyno run
Postby DLittle » Sat Mar 03, 2007 11:03 pm
I finally got to dyno my truck. I was hoping for 300hp/650 tq. I got the 300 actually 301hp. I knew my troque would be hard to hit with a stock super slip auto but I didn't think this much.I had 538.2 on torque.
My question to everyone that has dyno'd is look at where my max torque is in the rpm scale is it so high because of the auto ? Also I hit peak HP at 3300rpm ?
I guess I had better do some tranny work :D
Dana
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby wannadiesel » Sun Mar 04, 2007 6:59 am
Looks like the truck is running great at high RPM! I wish my curves looked like that. :x
Best dyno: 408/844
wannadiesel
diesel guru
Postby KTA » Sun Mar 04, 2007 11:27 am
Were they using a crank moumted rpm pickup? Why did they start the runs at 2000rpm? I think had they to have started at 1400-1500 you would have seen alot better torque numbers.
Postby MUDDY » Sun Mar 04, 2007 12:31 pm
they start the run whereever ya want em to.
just hard to keep the auto from downshifting at the lower rpm
yep,,crank mounted rpm pickup
93 D-350 dually
90 W-250
FOR IDAHO EVENTS WATCH
MUDDY
Postby 92 D/UNIT » Sun Mar 04, 2007 1:29 pm
nice curve dana, mine just comes on like crazy and falls off :cry:
388/886
92 D/UNIT
Return to Competition
