Fuel Additives?
Fuel Additives?
Postby seeker1056 » Wed Mar 18, 2009 7:38 am
I understand that Cetane can be an additve and is sold in bottles claiming to make your fuel 5-7 points higher.
Is there a point where one could add too much cetane and hamper performance
For pulling purposes I was thinking along the lines of say two or more bottles of additive per tank?
Anyone out there with experience with additives and/or "mixed" fuels?
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby MrHorsepower » Wed Mar 18, 2009 3:49 pm
This website had a lot of info for me. Maybe it can help you out too.
http://mopar.mopar1973man.com/tips/cumm ... le-oil.htm
In Progress: '84 Chevy Silverado dually w/19.5 rims.
1st gen, New Eras, s300, 366, DennyT, piston LP, Pacbrake, 60lbs. springs, ARP studs, Snow Perf. stage II, '97 DR IC, 4" stacks.
NV4500, 14 Bolt Locker & Dana 60 Posi w/3.73's
MrHorsepower
Postby dpuckett » Thu Mar 19, 2009 5:37 am
Cetane is a RATING, not an actual additive. There is very little, if any, cetane in diesel fuel. It is just a standard to which to compare the flamability (or some similar such characteristic) of diesel fuel. Same goes for octane in gasoline.
That said, most that claim to add cetane or boost the rating are just blowing smoke up your tailpipe. What you want is lubricity, esp with a fuel system designed 30 years ago or more, and today's dry fuels. I am running Schaeffer's Diesel something-or-other. About $6 a can, does 4 tanks. I deifinitely notice a difference if I do a few fill ups without it. After seeing the wear on my cam plate and rollers, I'm not running it vrey long without some lube agent. 2 stroke oil hasnt worked for me (I drop a MPG every time, but it does run quieter and smoother), so this is my only option, IMO. Unless I could find some bio to run in it.
Daniel
Postby T.winegar » Thu Mar 19, 2009 6:28 pm
hey dpuckett, where do you get the schaeffer's diesel stuff. i've been running a lucas oil additive and haven't noticed much of a difference.
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby okish » Thu Mar 19, 2009 9:08 pm
I run WMO and 2 stroke oil in both my 02 and 89.
89 D250- G360, Bombed VE, BHAF, 4 inch turbo back, 60mm h1e/h1c hybrid, 16cm3 pdr ported housing, custom 2.5 inch crossover pipe, denny t stg 2 fuel pin, piston lift pump.
okish
Postby KTA » Thu Mar 19, 2009 9:38 pm
Stanadyne performance formula and the fuel conditioner from your local John Deere dealer are 2 of the best additives available on the market.
You can see this chart of independent testing for results.
http://www.diamonddiesel.com/fueladditi ... ditive.pdf
Postby dpuckett » Fri Mar 20, 2009 6:49 am
I get the Schaeffer's through my fiancee's shop. One of the perks.....
Postby seeker1056 » Fri Mar 20, 2009 8:49 am
http://www.amsoil.com/storefront/acb.aspx
This was the product literature that got this thread started
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
