Braking deaht wobble
Postby VEfreak » Fri Apr 10, 2009 4:17 pm
When I brake between the speeds of 35-45 mph my truck goes into death wobble mode. If the speed falls below 35 it stops and if I accell past 45 it stops. Anybody got an idea of what it is.
Oh, and if I want steering or suspension parts for my truck like a new tie rod or a king pin rebuild kit, where should I get those.
I AM ZUES DAMNIT
VEfreak
Postby gear jammer 91" » Fri Apr 10, 2009 6:26 pm
There are a couple options. It could be warped rotors, but I think you would notice it all speeds. If it's not the rotors you need to check your spring and shackle bushings, from there I would check tie rod ends. It could be a wheel out of balance too, or maybe an alignment issue. Any parts store should be able to get you the parts you need.
01 LB7
gear jammer 91"
Postby RumbleFish » Sat Apr 11, 2009 6:44 am
gear jammer 91" wrote:There are a couple options. It could be warped rotors, but I think you would notice it all speeds.
not to mention, warped rotors woiuld give you a pulsating pedal.
dont skimp on the fornt end parts. i reccomend moog. got an oreilly's local?
Postby VEfreak » Sat Apr 11, 2009 1:37 pm
I got a napa, kragens, and autozone. I'll check the bushings and tie rod ends. The shaking is way to violent to be and out of balance tire. Thanks guys.
I AM ZUES DAMNIT
VEfreak
Postby RumbleFish » Sat Apr 11, 2009 7:31 pm
go for kragens. oreillys just merged with them...or more like bought them out. afaik they should be able to get the moog stuff.
Postby charbles » Fri May 22, 2009 8:01 pm
I've had similar, and when I rotated the tires it totally stopped. Now it's happening again, about the time I'm due a rotation. It's worth a try, for sure.
1990 W350, 727, Mostly on Bio
charbles
Postby Ezra » Fri May 22, 2009 8:14 pm
Could be your axle u-joint too.
93 W250,auto,3.54's..167k miles..asa modified intake.stans 4in,.industrial injection pump.6x.016's..S300 62/71/14..piston lift pump..And still more to come.
Ezra
Postby cougar » Sun May 24, 2009 9:24 am
Take a look here and see what I am going through to fix mine.
http://1stgen.org/viewtopic.php?t=4745
With the age, miles, and stress put on our trucks something(s) has give.
01 2500 "the work truck".
cougar
