Puff of black smoke on startup
Postby ontos » Fri Apr 10, 2009 12:52 pm
Just finished installing an intercooler on my Non I/C 1st gen.
Runs fine once I got all the tubes tight. When I start it there is a short puff of black smoke. Is this a problem?
It also takes a while longer to warm up (40's today) with white smoke but none when it warms up.
I expected to loose some boost but not sure yet.
Thanks any info or opinions.
J Golden
89 5.9 non IC Freightliner motorhome Chassis 545 Allison
ontos
Postby RSWORDS » Fri Apr 10, 2009 2:20 pm
The little puff is normal on start up. If i remember correctly I think teh VE pump shows full throttle until about 300rpm.
RSWORDS
Postby gear jammer 91" » Fri Apr 10, 2009 6:27 pm
That little puff is perfectly normal. Once you turn the power up that little puff get bigger.
01 LB7
gear jammer 91"
Postby ontos » Fri Apr 10, 2009 6:40 pm
Thanks, never had it before I added the I/C so I thought I'd check.
It's been turned up for a while, in fact I had turned it back a bit. See how it goes with the I/C.
Thanks again
ontos
Postby gear jammer 91" » Fri Apr 10, 2009 7:44 pm
I added an intercooler to my truck, after it was on it seemed like there was more smoke off idle. I guessed it was because the intercooler and piping added a small amount of turbo lag that wasn't there before.
01 LB7
gear jammer 91"
Postby ontos » Sat Apr 11, 2009 5:37 am
That make sense, and my piping is a little longer than the pickup deal plus the cold outside temps all add to the effect.
Thanks.
ontos
