Knotching the pistions
Postby 2wd_sled_puller » Tue Apr 14, 2009 3:27 pm
At what size injectior do u have to worry about this??
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby cummins king » Tue Apr 14, 2009 3:38 pm
None it doesn't matter what size injector you run it might matter if you don't run any sealing washer
93 4X4 auto
cummins king
Postby 2wd_sled_puller » Tue Apr 14, 2009 4:15 pm
cummins king wrote:None it doesn't matter what size injector you run it might matter if you don't run any sealing washer
U have a number u can pm me to contact you. U are just the 1st gen guy im looking to talk to if u dont mind
2wd_sled_puller
Postby mprmn08 » Tue Apr 14, 2009 5:53 pm
the only time you should have to notch the piston is with a bigger cam or like CK said MAYBE with no washers on the injectors.
mprmn08
Postby KTA » Tue Apr 14, 2009 9:17 pm
You should never run injectors without sealing washers, but even if you did they wouldn't be close to the piston.
Postby LOGANSTANFORTH » Fri Apr 17, 2009 3:42 am
the injectors would gave to stick out probably a 1/2 inch before they even got near the piston......
THEY PUT THEM ON A PLANE TO SOME STRANGE AND FOREIGN LAND, THEY SAID GOODBYE TO MOM AND DAD AND HELLO TO UNCLE SAM, THEY NEVER THOUGHT THE DAY WOULD COME WHEN THEY MIGHT HAVE TO KILL A MAN, THEY DID NOT SLEEP A WINK THAT NIGHT BUT THEY WON FOR UNCLE SAM
LOGANSTANFORTH
Postby PToombs » Fri Apr 17, 2009 1:42 pm
Boy, he's easily impressed, huh? :roll:
:jumpsmile:
