W/A or A/A Aftercooler?
Postby SicNick » Fri Apr 17, 2009 12:50 pm
As some of you know, I recently completed my 1990 6bt into 84 Chevy K30 swap, anyway summer time is here and it is time for the final stages with involve intercooling and adding A/C to my truck.
The empty weight is around 8500 lbs, it has a 4" lift on 35's and the most Ill ever tow is about 10k max. So do you guys think Id be better off with a stock first gen intercooler or a liquid air kit from frozenboost, ( their 600 HP kit) I live in the west and commonly deal with 100* summers and 0* winters. Also Im looking to settle in at 300hp.
Thanks for the opinions!
1984 K30 powered by 1990 6BT
SicNick
Postby bgilbert » Fri Apr 17, 2009 1:41 pm
Air to air all day for a non-competition truck. The stock 1st gen intercooler has been proven to produce all the 600+hp Stomp made and my lowly 523hp (up to this point ;) ).
Bill Gilbert
Postby RSWORDS » Fri Apr 17, 2009 1:53 pm
bgilbert wrote:Air to air all day for a non-competition truck. The stock 1st gen intercooler has been proven to produce all the 600+hp Stomp made and my lowly 523hp (up to this point ;) ).
Wait a min bill... You just gave me hell about wanting to put a a-w in my competition truck. :lol:
MAKE UP YOUR MIND!!! :lol:
RSWORDS
Postby gear jammer 91" » Fri Apr 17, 2009 4:33 pm
If your not gonna be towing I think you should be able to cool 300HP without an intercooler if you run a good turbo like an hx-40 or an S300.
01 LB7
gear jammer 91"
Postby SicNick » Tue Apr 21, 2009 8:16 am
As stated above, I will be towing up to 10,000 lbs every once and a while, in hot weather at high elevation. Thanks guys
SicNick
Postby RSWORDS » Tue Apr 21, 2009 9:30 am
SicNick wrote:As stated above, I will be towing up to 10,000 lbs every once and a while, in hot weather at high elevation. Thanks guys
Air to air or water injection is going to be your best bet then
RSWORDS
Postby SicNick » Tue Apr 21, 2009 11:48 am
thanks, so no one has real world experience with the water to air setups then? on a DD atleast
SicNick
Postby RSWORDS » Tue Apr 21, 2009 12:12 pm
SicNick wrote:thanks, so no one has real world experience with the water to air setups then? on a DD atleast
I think the factory air to water setups were ok. They used them in rear engine busses. They really seem to shine in competition only setups were you can run ice water in them. For a DD that tows an air to air is your best bet
RSWORDS
