slowdiesel wrote:I will have to go and and measure it for you, I would say its about 3 or 4 inches I cut out of mine. You can only go as far as the springs witch are mounted on the outside of the frame. If you move them to the inside of the frame rails, wow you can fit a big tire under there.
RumbleFish wrote:ive seen a few gasser drag trucks in the 72-93 body that use 2 sets of factory wheels wells to tub it with a factory-ish appearance. i always planned on that for my big block short bed, which will never happen now that i have found diesels. basically, you use part of another wheel well to make a wider well in the bed. its pretty slick.
KTA wrote:Why not just use a dually bed? Then you can fit a ton of wheel!!
93_Fummins wrote:gives added benifit of less axle wrap....
