Vinyl instead of carpet anyone tried these?
both inside and out
Postby redneckroot » Tue Apr 21, 2009 7:30 pm
Has anyone tried one of these to replace their carpet? I hate the way carpet holds moisture and rots out the floor boards.
http://www.automotiveinteriors.com/carp ... _93acc.htm
redneckroot
Postby Farmboy » Wed Apr 22, 2009 5:08 am
No, but if you do try it let us know how it works out... I would love to ditch the carpet.
Farmboy
Postby cummins4life875 » Wed Apr 22, 2009 11:45 pm
im just gonna use rhino liner heavy duty no moisture and easy to clean
cummins4life875
Postby Ace » Fri Apr 24, 2009 12:17 pm
cummins4life875 wrote:im just gonna use rhino liner heavy duty no moisture and easy to clean
That's probably the way to go if you want to do the minimalist thing for a work truck or off-roader. You are probably gonna find a vinyl mat will hold moisture and rot the floors even faster than carpet.
Postby PToombs » Fri Apr 24, 2009 6:04 pm
I notice it comes with the jute pad. That will help with noise, but will hold the moisture just like carpet.
I couldn't believe how much noise the stock rubber mat and the padding cuts out. Big difference!
Postby lincoln » Fri Apr 24, 2009 6:19 pm
If carpet and mats hold moisture, would rinoliner under the pad and mat keep moisture out and cut down the noise?
1992 W250 Single cab 5spd (stock)
1993 W350 Ext. cab drw 5spd (stock)
lincoln
Postby dpuckett » Tue Apr 28, 2009 7:48 pm
I had some of that vinyl in my old (rumblefish's) D350. Not bad, but I'd install some more sound proofing under it, preferrably the water resistant kind. It is definitely loud with just the vinyl.
And for what it's worth, the carpet has a thick rubber backing, so either one will rot the floor if you get water in the cab.
Dan
Return to Body
