turbo upgrade
turbo upgrade
Postby Firstgen1 » Mon Apr 20, 2009 1:21 pm
im a new member here, i love this site, anyways i was looking for a 60mm turbo upgrade and one comes with an 8 fin propeller and one comes with a 6 fin propeller, whichone is better and how much boost will i get
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby Ace » Mon Apr 20, 2009 2:56 pm
The turbo will just flow more air = lower EGT. Boost comes from fuel.
Postby SChandler » Tue Apr 21, 2009 5:48 am
The 6 blade upgrade will move more air. Boost, as Ace said, will depend on your fueling level. Some of the guys who have ran the compressor upgrades would have more info for you.
SChandler
Postby Firstgen1 » Tue Apr 21, 2009 1:38 pm
ok thanks guys my egts are 1200 at wide open throttle up a mtn so is the upgrade worth it
Firstgen1
Postby peobryant » Tue Apr 21, 2009 2:04 pm
Firstgen1 wrote:ok thanks guys my egts are 1200 at wide open throttle up a mtn so is the upgrade worth it
According to Cummins, you can run 1200* all day long with no harm done.
Postby Ace » Wed Apr 22, 2009 12:06 am
It looks like you are already maxed out for available fuel, so probably not worth it. If you can get more fuel somewhere - the fuel screw, throttle travel or delivery system (lift pump, etc. ) maybe.
I can get pretty hot (saw 1300 and climbing once) with my current setup including a Powerstroke I/C and the 60mm hybrid upgrade. I suspect you either have more fuel hiding somewhere, injection pump getting tired, or possibly lack of delivery.
Postby dpuckett » Mon Apr 27, 2009 10:41 am
Or, he has a well tuned engine. Mine tops out at 1200EGT, and will keep up with most of the newer ones.
Postby ontos » Fri May 01, 2009 8:21 am
dpuckett wrote:Or, he has a well tuned engine. Mine tops out at 1200EGT, and will keep up with most of the newer ones.
I'm at the "stayed at a Holiday inn" level of knowledge here so i only speak from my own experience. I did an upgrade to a 58mm compressor wheel from a 50mm. Before the upgrade my extra fuel turned to heat, after the air increase (also opened up the crossover and exhaust pipes) more power less top egt's.
The "well tuned" point is a good one. Every time I make a change it screws up the deal until I study up from the smart folks and move up to a better running more powerful deal.
I just added an I/C and now I have to get back the the fuel air balance. Smoke at start up and slower spool up to cure. Need to get to "well tuned"
89 5.9 non IC Freightliner motorhome Chassis 545 Allison
ontos
Postby Ace » Fri May 01, 2009 9:44 am
ontos wrote:I just added an I/C and now I have to get back the the fuel air balance. Smoke at start up and slower spool up to cure. Need to get to "well tuned"
I would check real carefully for boost leaks and go over everything to make sure nothing's out of place. Just installing an I/C should not have that effect.
Mine outruns most of the newer ones - "if" I can get it into 3rd gear quick enough. 8)
Postby PToombs » Fri May 01, 2009 5:41 pm
Joe, how many feet of pipe did you have to add to reach the I/C?
Postby ontos » Sat May 02, 2009 11:44 am
hey, Pete. glad to see your are back on the active list.
Might be 3 feet total more than a Dodge would have. The freightliner engine to Rad space is greater and plus from the I/C back. No doubt the distance slows the boost spool up. seems to top out the boost about the same.
I had planned to take it for a test ride out west( Diesel in OK not much more than Gas), but found a broken shock hanger the day I had to leave and made it a car trip. The little bit the weather warmed has reduced the smoke a lot.
ontos
Postby PToombs » Sat May 02, 2009 5:45 pm
Yup, back up to snuff! ;)
Joe, that was my thought, the extra length affecting the spool.
Postby ontos » Sat May 02, 2009 7:54 pm
True, hard to beat the short crossover pipe for quick response. maybe for nonI/C the right watermeth setup would have been a better choice than the I/C.
Have to take a ride out to Turningstone to get a good feel for how it works.
ontos
