Ramrod90 wrote:Since you have an automatic trans, you could also get away with buying an HX40 which you could pick up for pretty cheap and flows about the same s a base model (57mm) S300. just a thought.
Richie O wrote:Less barky barky with an auto. Mash and go. 40's no likey barky.
dcube wrote:What is the difference between an hx40 and an hx40w? Is the hx40w good to install on a 1st gen?
Doug
'91 Cummins wrote:dcube wrote:What is the difference between an hx40 and an hx40w? Is the hx40w good to install on a 1st gen?
Doug
As far as I know, the W just means wastegated. I haven't heard of a non W/G HX40 though.
