1stgencummins wrote:I have a 92 cummins with a 727 3 speed with overdrive. I have pods in it. cold air intake. fuel screw cranked in. ground fuel pin. timing advanced. smoke screw turned in. I have a stock turbo on it and I am only getting about 25 psi of boost I think I should at least be running 28 or 29 how do I get more boost any one know. your help will be greatly appreciated thanks
1stgencummins wrote:My tranny is not slipping. my truck has only 90,000 miles on it. I plan on yanking the tranny and doing all that stuff to it i just have not had any time to do it. which I am only 16 and I try to get all of my specs right but some times i goof up. I will try that soapy what thing and check for leaks
RumbleFish wrote:i thought the autos didnt like the 12cm housing?
