Guy's IN ONTARIO
Guy's IN ONTARIO
Postby cummins king » Thu May 07, 2009 8:07 pm
Hey Guy's
For those of you who don't know, on May 9th, TDR is hosting the spring Dyno at Diesel Doctors, in Georgetown, ON. It starts at 9am.
Its $50 to dyno you get 3 pulls, or $5 bucks for some lunch.
Should be a good time, i keep missing it but i hear there is 25 to 40 trucks that come.
http://www.dieseldoctorsltd.com/contact
CK
93 4X4 auto
cummins king
Postby peobryant » Thu May 07, 2009 8:52 pm
Is that where you are going to dyno your truck?
Postby cummins king » Fri May 08, 2009 5:29 am
I hope to, things are going good, its supost to rain tomorrow so i might be able to step out and go for a bit.
93 4X4 auto
cummins king
Postby seeker1056 » Fri May 08, 2009 8:10 am
git er done n good luck
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Fri May 08, 2009 3:00 pm
Agreed!
I got that oil pan on yesterday and i retorque my head. then i crancked my timming from the retarted side all the way to the advance side(im advanced one tooth).
And i topped out at 160kms, a big jump from 140kms. and it corrected my ruff idle, now it runs really nicely.
Tonight im going to cranck my fuel screw in abunch, its about 1/2 way now, and get my custom injection brew ready.
Its supost to rain so im thinking its a go.
93 4X4 auto
cummins king
Postby seeker1056 » Sat May 09, 2009 3:26 pm
WELL????????????????
do you need the wammy slug?
Lol :lol:
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Sat May 09, 2009 4:16 pm
ya I need it, try 275 hp with 700 foot pounds of torque, but before u laugh ur self off the chair, the dyno sucks, I counldnt light the bottom turbo nomatter how hard I was on the breaks. I top out at 55 pounds of boost, which on the street I can hit 100psi. The smoke was so bad cuz it wouldn't light that it cleared the 3 bay shop.
So what I think is I'm going to take it to a 1/4 mile trake and estmste the up that way, or sell my tranny and put a five speed in.
93 4X4 auto
cummins king
Postby Begle1 » Sat May 09, 2009 5:04 pm
How about a better dyno setup?
Postby seeker1056 » Sat May 09, 2009 7:00 pm
me thinks yur injectors be too big
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby cummins king » Sat May 09, 2009 9:27 pm
seeker1056 wrote:me thinks yur injectors be too big
What? Of it was only a single but it's twins, and I couldn't light the bottom, so?
93 4X4 auto
cummins king
Postby KTA » Sat May 09, 2009 10:24 pm
Was it a dynojet? If not what kind of dyno was it? Sounds like it might be time to put the AFC lever back to functional operation so you can get those turbos lit instead of over fueled.
Postby cummins king » Sun May 10, 2009 12:29 pm
Its a DYNO-mite chassis dynamometer, and i do have an AFC in.
I can light it on the street fine, and it clears the smoke fine, but since the bottom one wouldn't light, it was a crazy admount of smoke!
Im wondering if i should feed the bottom one directly from my manifold?
93 4X4 auto
cummins king
Postby seeker1056 » Mon May 11, 2009 4:18 am
Just sum thoughts
with or without the second turbo lit you had 50 psi boost correct?
your hx40 wasnt very likely makin that boost all by itself for sure so the bottom turbo was doin sumthin I would think
did it lite on the way home? at what mph does it lite? or rpm? I ask because you keep tellin me about the upper kph of 140-160 which is serious rpm with no OD
for example my old twins would lite at 1600 rpm and be all in by 2400 rpm or 25kph start in first gear at which point i could drift the truck at will
second gear starts would lite at 15kph
I am also curious about the 100 psi boost claim on a hx40 and 60 combo - sure the gauge is workin properly as that sounds awfully high? I woulda thought 65-70 tops
in any event you need a boost guage between the turbos and after so you can see what each is doing
did you run the truck to test after you ran the fuel screw in and turned the timing up just before the dyno run - maybe you just outwitted yurself by palyin with the setup you had?
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
