Head work done...
Head work done...
Postby SNOOT » Fri Apr 24, 2009 3:57 pm
Getting ready to install the head next week or so. Had special springs installed and an O-ring job done.. Cant wait. This is the best picture I can post..No close up photos..
Reference picture...stock valve springs
1993 W350
SNOOT
Postby gear jammer 91" » Fri Apr 24, 2009 7:29 pm
Nice! I'm hopping to get a hold of used head to have the same stuff done to soon. Let us what kinda power gains you see.
01 LB7
gear jammer 91"
Postby mprmn08 » Sat Apr 25, 2009 3:45 pm
just out of curiousity are you plannin on a big cam or something cause those look to be some pretty heavy springs?
mprmn08
Postby randyswelding » Sat Apr 25, 2009 6:45 pm
ditto on what cam and did it get ported and polished?
randyswelding
Postby SNOOT » Sat Apr 25, 2009 10:00 pm
Yes a cam also have a photo of it next couple days..
1993 W350
SNOOT
Postby dpuckett » Mon Apr 27, 2009 10:43 am
The heavy valve springs could also be for higher RPM running- stockers are only dependable to about 3300rpm or so. Not saying I havent turned more, but I wouldnt recommend it on a daily basis.
Dan
Postby SNOOT » Mon Apr 27, 2009 2:15 pm
I don't run a tach but the pump is set to govern at 3.5K right now.
1993 W350
SNOOT
Postby SNOOT » Tue May 12, 2009 6:23 pm
Cam was installed over the weekend... All went well.. I cant wait to get some fuel to this thing!!
1993 W350
SNOOT
Postby SNOOT » Tue May 12, 2009 6:27 pm
Just so you all know what truck we are working on..
1993 W350
SNOOT
Postby jensenkennels » Tue May 12, 2009 7:57 pm
That truck has sexy written all over it!
jensenkennels
Postby KTA » Tue May 12, 2009 10:10 pm
It is a shame you cut that mint core support to put the cam in. :cry: It looks like you have a lot of nice goodies on there though!! It should be a good reliable runner. Those look like chevy valve springs though is that a dual spring with dampner setup? What kind of seat pressure do you plan to run?
Postby SNOOT » Wed May 13, 2009 7:01 am
I will weld the core support back in and post a picture to make you feel better. I cant tell you the exact springs used. lol The builder is anal hush . hush. They are a single spring with dampner. Seat pressure is not super crazy I also have better valve seals installed in they some place.
1993 W350
SNOOT
Postby SNOOT » Tue Jun 02, 2009 9:53 am
Man this stuff takes time...
Rockers machined ... Check
Block surface cleaned ... Check
Stud holes tapped and cleaned... Check
1993 W350
SNOOT
Postby Richie O » Tue Jun 02, 2009 12:09 pm
My check list includes.
Look in undies for skids- check
Sniff arm pits- check
Good for another week. :D
Things are looking good. ;)
Postby SNOOT » Tue Jun 02, 2009 5:52 pm
Richie O wrote:My check list includes.
lol
1993 W350
SNOOT
