So, on the subject of lift pumps, what do yall advise?????
soggy wrote:Link doesn't work, but there is a list of part numbers for everything you need floating around somewhere, maybe one of the other guys will be kind enough to get it to you.
gear jammer 91" wrote:Piston pump install:
http://www.dieseltruckresource.com/d...ad.php?t=93722
Here's a link over to a wright up on how to do the piston pump install that was posted over on DTR. It's a good wright up with pictures and the part numbers. I did this upgrade on my truck, it's definitely worth the time and really only takes about an hour. I was able to cut the insulation that needs to be removed with a box knife.
