SOOT4BRAINS wrote: . The gear is retained in the case, and cant move enough to jump teeth. Good luck!
Wrong it can jump if you rotate the engine.. Trust me I know for a fact.. JFYI
SNOOT wrote:SOOT4BRAINS wrote: . The gear is retained in the case, and cant move enough to jump teeth. Good luck!
SOOT4BRAINS wrote:SNOOT wrote:SOOT4BRAINS wrote: . The gear is retained in the case, and cant move enough to jump teeth. Good luck!
Oops, sorry guys. When we did my friends pump replacement, we were told by the pump company that it could not move enough to jump teeth. His plastic TDC pin is broken too, so we took the old pump off, then rotated it by hand till the keyway looked like it lined up with the new one which was locked at TDC. I guess we just got really lucky it didn't jump. Thanks for the info.
