Hey all, I've got an actuator from an HX40 that I was hoping would work on my H1C with 14cm housing and HTT upgrade. I had my turbo off and was going to bolt this thing right on but I realized that the bracket points straight to the comp housing and hits the oil drain tube. Do i have to clock the drain tube around a little or Should I try to find an actuator that sticks out the side rather then points to the comp housing? Thoughts and answers please! Thanks
Dan
