I had a guy give me a bunch of Honda ATF. Anyone use tranny fluid in their fuel?
Does it increase lubricity?
Begle1 wrote:Did Type F or any other fluid use sand or some kind of particulate as a friction modifier?
PToombs wrote:In the old days when they ran Detroit Diesels they used a lot of it. I bet they tried anything to get more out of those!
There is no grit of any kind deliberately placed in any lubricant. The friction coefficient of Type F fluid was originally matched for use in early Cruise-O-Matic transmissions, which at the time had a couple of bronze/steel clutches in them. Ford continued to use Type F, and build transmissions to use it, well beyond the time when the last bronze clutch Cruise-O-Matic was built, and into the late seventies, when it was gradually replaced by the Mercon standard, which eventually became completely aligned with the Dexron specification. Type F has a slightly heavier viscosity than Dexron II or III, and there was a time when it would attack the adhesives used to make GM and Chrysler clutch linings, but that's not really an issue here.
Ace wrote:Begle1 wrote:Did Type F or any other fluid use sand or some kind of particulate as a friction modifier?
I've heard alot of crazy myths about oil like synthetic is slipprier, pennzoil causes sludge, etc, etc, but that's a new one on me, and may just be the most outrageously ridiculous one I've heard yet.
