black smoke anyone???
Postby bigbadbear » Mon Jun 08, 2009 10:12 am
hey guys, i just found this forum and haad to join in. i got a 91.5 intercooled ram 4x4. she used to be my daily driver til i bought an 03 cummins for work n such. now i just want that ol gal for pleasure cruzes, i just want thick black smoke, for a good deal. shes stock other than the 4" exhaust and turbine housing. any ideas are appreciated! ps, full economy is no concern anymore so gimme the goods!
91.5 Ram 4x4 single cab flatdeck. 4" turbo back, 16cm turbine housing.
bigbadbear
smoke screw?
Postby RSWORDS » Mon Jun 08, 2009 11:12 am
put a plastic bag over your airfilter... That should do it.
RSWORDS
Postby SOOT4BRAINS » Mon Jun 08, 2009 11:56 am
Crank the full fuel screw up, back the idle back down to normal, and remove the afc lever. All free, and it'll waste enough fuel to make a small cloud. Won't be too bad, only smoke when you want it to. Plastic bag over the air filter is easier tho :D
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby JQmile » Mon Jun 08, 2009 12:49 pm
Put a lift pump and 6x16 injectors in, and let off when you hit 1600 deg or your turbo explodes :D
JQmile
Users browsing this forum: No registered users and 102 guests
