Wheels of hummer
Wheels of hummer
Postby 1stgencummins » Wed Jun 10, 2009 5:41 pm
Will Wheels off a hummer fit on my 91 (off set not sure )
1stgencummins
Postby Bogie » Wed Jun 10, 2009 6:10 pm
Not unless you have them re centered as they have about 7" of backspacing I have seen then used on a dully axle.
here is a guy on Pirate that does it but search around there a lot of places offering to make centers the dual bead lock is a nice benefit.
1984 Dodge W350 Crew Cab 9"Lift 37" SSR's 360/NP435 D60's W4.10's
1966 Dart 273HP 4Speed 3.90's Radio/Heat Delete
Bogie
Postby CE_TX » Wed Jun 10, 2009 6:40 pm
Like Bogie said you have to run dually axles front and rear or at least dually up front and 2" spacers outback. To make your SRW axle a DRW axle is pretty simple. All you have to change is the bearing hubs and rotors, everything else swaps over. Well the wheel studs are different also.
Here is a pic of my old 77 M880 running DRW Dodge dana 60 up front and a van width 14FF (about the same width as a dually truck axle) out back. Worked great.
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Postby RumbleFish » Thu Jun 11, 2009 5:32 am
^^^thats badass!
Postby CE_TX » Thu Jun 11, 2009 6:49 pm
Thanks!!! I miss the old truck, but got in a tight for money and parted it out.
Here is a pic of her showing off a new set of 42s.
CE_TX
