egt loss???
egt loss???
Postby hassy21 » Tue Jun 09, 2009 2:38 am
ever since the 36's and the lift i cant get the pyro over 1100. befor with 33's and stock lift i could hit 1400 which i didnt like but was fun goin fast. what could be the reason?
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby dpuckett » Tue Jun 09, 2009 12:26 pm
Loss of resistnace to wheel roll and resistancve to drivetrain roll? Whatever it is, keep track of it and report back to us.
Is your acceleration any slower than before?
DP
Postby hassy21 » Tue Jun 09, 2009 12:47 pm
ya on my other post i put that i lost about 20 mph on top end but thought that the tires made the speedo that far off but the egt loss make me think it is the converter. the tranny only has about 3,000 miles on it with a rebuilt stock converter.
hassy21
Postby dpuckett » Tue Jun 09, 2009 12:54 pm
Rebuilt stock convertor answers your questions. They are junk at best. Change your convertor for even a Hughes and you will notice a difference, to say nothing of a DTT or Goerends Bros.
DP
Postby KTA » Tue Jun 09, 2009 7:09 pm
Sounds like for some reason you aren't getting as much throttle travel anymore. Have you had someone floorboard it while you look at the linkage on the pump to make sure it is pulling all the way against the high idle stop?
Postby Ace » Tue Jun 09, 2009 9:01 pm
Bigger tires and lift should make it run hotter because it has to work harder to accelerate and cruise at the same rate as before. At least it did on mine.
Postby hassy21 » Tue Jun 09, 2009 9:12 pm
ya i had someone floor it and i checked it it was a little off from what it was before but i wouldnt think i would lose 300 to 400 degrees. i adjusted the timing and lost a little more travel also. how would you get more throttle without buying a new throttle cable(assuming it has stretched over the years)?
hassy21
Postby SOOT4BRAINS » Tue Jun 09, 2009 11:29 pm
The linkage with the 2 ball joints on the end should be adjustable. Just make it a little longer or shorter to accommodate the timing adjustment.
93 D250 Rag 3.54, 4 inch stans downpipe to custom 4 in exhaust, pump cranked with m3 pin, 366 spring, tach,boost,pyro,fuel pressure, ddp 70lpm sticks, 62/65/12 s300, airdog 150, rebuilt getrag, 3250 SBC clutch, helix 2 camshaft, dual redtops, new paint.
SOOT4BRAINS
Postby hassy21 » Wed Jun 10, 2009 12:12 am
wouldnt that raise my idle?
hassy21
Postby fergavs » Wed Jun 10, 2009 12:14 pm
Adjusting the rod should have no effect on idle speed. You should have full travel of the linkage so at rest it sits on the idle adjustment scew and at WOT it should be hitting the afc housing on the pump.(or the high idle screw if u still have one) If it does not hit those items then you don't have full travel. Loosen both nuts on the rod with the ball ends. adjust it so at idle your linkage sits on the idle screw. then have some one push the pedal wide open. If it doesn't go all the way you can try a number of tricks to get it to move further. Some guys find it handy to swap where the ball end attaches to the linkage. They swap it to the hole where the return spring used to be, this gives more travel. (there is another thread on doing this with pics if you search) Anyway basically you need to get full travel because just a little lost throttle makes a huge difference, at least it does on my 2 trucks.
fergavs
Postby hassy21 » Wed Jun 10, 2009 12:52 pm
ok thanks ill try that in the next couple of days
hassy21
Postby hassy21 » Thu Jun 11, 2009 12:00 am
my cable linkage is in the right spot but i found that the spring deal that is attached to the bracket on the side of the block was bottoming out and not letting me get full throttle. so i just cut it off and also adjusted my skinny pedal like 1 1/2". feels like the 20 mins. of work that i did got me an extra 50 hp!!!
hassy21
Postby hassy21 » Wed Jun 17, 2009 1:25 am
my egt's are still maxing out low. since adjusting the throttle it only hits 1200 degrees. any ideas? what is a good converter if that is the only possible problem?
hassy21
Postby Richie O » Wed Jun 17, 2009 5:15 pm
Your either not loading the engine ( slip ) or your not getting as much fuel as you were getting before.
Postby peobryant » Wed Jun 17, 2009 5:42 pm
hassy21 wrote:my egt's are still maxing out low. since adjusting the throttle it only hits 1200 degrees. any ideas? what is a good converter if that is the only possible problem?
You want to talk to Dave Goerend if you want a new converter. [/u][/i]
