I need to clean this mess up.
Postby BC847 » Sat Jun 13, 2009 12:43 pm
KTA wrote:One gear tooth is 10deg of rotation, but that is in total reference to the pump therefore it is 20 deg in reference to the motor.
Hmmm . . . . based on that exclusively, compared to the stock/OEM timing, I'm advanced past that approximately 40 crankshaft degrees? :shock:
Postby BC847 » Sat Jun 13, 2009 8:35 pm
Am I correct in thinking that our 4-stroke engine would have the crankshaft rotate four times to the one of the IP?
Postby Richie O » Sat Jun 13, 2009 8:43 pm
I would say 2 turns crank one turn cam and pump.
Postby BC847 » Sun Jun 14, 2009 6:50 am
I backed it off a wee bit. ;)
Postby BC847 » Tue Jun 16, 2009 1:28 pm
BC847 wrote:Am I correct in thinking that our 4-stroke engine would have the crankshaft rotate four times to the one of the IP?
Sometimes I wonder about me. :shock:
Postby RSWORDS » Tue Jun 16, 2009 6:57 pm
Does anyone have any pics of the front of the engine with the cover removed? I'm really having trouble wraping my brain aroun what I need to do to advance my timing 1 tooth. I think its because I've never had my cover off and the few pics I havve seen I never paid attention too. just trying to get a game plan together.
Thanks Guys!
RSWORDS
Postby PJ 3 » Tue Jun 16, 2009 7:09 pm
I've seen one before but can't remember where. Might have been cummins forum. If I find it I'll copy and paste it for ya.
Pete
1992 W250
PJ 3
Postby PToombs » Wed Jun 17, 2009 6:01 pm
Snoot posted one recently where someone was asking about the timing marks. In the last month, IIRC.
Postby RSWORDS » Wed Jun 17, 2009 6:27 pm
Thanks pete, I found one, so if I'm thinking correct I need to pull the front cover, pull this gear and rotate it and teh pump shaft one tooth clockwise. Correct? I still dont understand why I'm having issues with this. :lol:
RSWORDS
Postby BC847 » Wed Jun 17, 2009 6:30 pm
Talking about IP timing, I've recently read elsewhere that "according to the book", 1.20mm lift roughly equals 12* (for example). It seems I recall reading that a long while back.
Ever heard of such? :?
Bobby, seriously, you'll spend more time messing with the gear-case cover than advancing the IP. ;)
Postby crewcabxlt » Wed Jun 17, 2009 7:15 pm
i,ve come across old posts from "pastor bob" stating simular, but even he seemed a little uncertain. im tempted to find a local shop with a pulse pick up and check or put up the money and get one.
78 ford crewcab,90 6bt,120k,pods,hx-35-12,ported parts.pump mods,3rd gen intercooler.dyno @298rwhp,808 tq uncorrected @4800 ft,dyno june 09 w/he-351turbo,364 rwhp-tq?,3 other 1st gens on the farm.
crewcabxlt
Postby RSWORDS » Thu Jun 18, 2009 5:04 am
BC847 wrote:Bobby, seriously, you'll spend more time messing with the gear-case cover than advancing the IP. ;)
I know david, I just need to go pound a couple cold ones and have at it! I have a tendency of over thinking things before I dive into them. Then I have a couple beers and all teh pre-planning goes out teh window. Its worked so far! :lol:
RSWORDS
Postby BC847 » Thu Jun 18, 2009 5:32 am
RSWORDS wrote:Thanks pete, I found one, so if I'm thinking correct I need to pull the front cover, pull this gear and rotate it and teh pump shaft one tooth clockwise. Correct? I still dont understand why I'm having issues with this. :lol:
Just so it's been said, the gear with the red arrow is in fact the accessory drive gear for the vacuum pump / power steering.
The gear for then IP is the big one at the top of the image. ;)
Postby RSWORDS » Thu Jun 18, 2009 5:40 am
:oops:
RSWORDS
Postby PToombs » Fri Jun 19, 2009 6:11 pm
Yeah Bobby. Clockwise is the hot ticket. I had to look at it and think about it 3 times before I was sure. :oops: I need more beer too! ;)
