which turbo?
which turbo?
Postby Bad93Cummins » Wed Jun 17, 2009 8:16 pm
super HX40 for $900 shipped after rebate
I can get you a 57/65/14 for $900 shipped after rebate
S300 62/65/12 $920 shipped after rebate
Its a Daily driver, tows my mud truck and atv's and hauls a pallet of salt ever now and than and help buddys hual stuff sometime's. Just tring to get alitte more power and some black smoke.
Bad93Cummins
Postby peobryant » Wed Jun 17, 2009 10:27 pm
What fueling mods do you have right now?
Going to a bigger turbo will decrease black smoke, and have lower boost numbers, not the other way around.
Postby Bad93Cummins » Thu Jun 18, 2009 4:50 am
Nothing right now, the only thing I have right now is the 4" straight pipe.
Im going to work on getting the turbo, hughes TC, Denny T fuel pin and make my cold air
Bad93Cummins
Postby RSWORDS » Thu Jun 18, 2009 5:11 am
KTA put up a teh Flow rates of the 57 S300 vs teh Super HX40 and the super 40 flowed more. So if it was between those two I would go that route.
For me though I would go with the 62/65 S300 For the $20 extra you get ALOT nicer turbo with a stronger shaft and one that will flow more air then teh Super 40. Also with teh 65 wheel and 14cm housing spool up should be great.
And 91 is correct, you will get less smoke (more power) with the bigger turbo and a lower boost number at the same lbs/min. Really though you will see the same boost number if not more. I went from 42psi with my H1C/H1E Hybrid to 55 with my Silver 62.
RSWORDS
Re: which turbo?
Postby bgilbert » Thu Jun 18, 2009 5:30 am
Bad93Cummins wrote:super HX40 for $900 shipped after rebate
I vote for the 62/65/12. Make sure you get the 12cm or .70ar housing. It will work better/spool better for towing/less hp trucks than the 14cm or .80ar housing.
What's with the rebate? Who are you getting these through?
Bill Gilbert
Re: which turbo?
Postby RSWORDS » Thu Jun 18, 2009 5:43 am
Bill I think he is going through this guy
http://www.dieselbombers.com/diesel-auto-power/
I've never personally delt with him but have heard good things.
RSWORDS
Users browsing this forum: No registered users and 89 guests
