Leak from above fuel filter
Postby Diezeldriver » Sun Jun 21, 2009 9:26 am
I noticed this awhile back, but have been lazy and haven't been too concerned. I figured its time I should try to solve it.
Somewhere above the fuel filter is a fuel leak and I have not been able to identify the cause. Has anyone had a similar problem and fixed it? Or does anyone have any ideas for a solution?
92 W250 Club Cab, cut fuel pin, fuel screw turned up, M&H timing device, POD injectors, K&N filter, 4in exhaust from the DP back, 16cm turbine housing, Autometer Ultralite 2 guages, Suncoast 47RE transmission, Ruenel Bumpers, Best 1/4 14.51 @ 90mph.
96 2500 reg cab CTD: 60# valve springs, silverbullet, switch to lock, afc, 4k gov spring, no plate, 4in dp to 6 in stack
Diezeldriver
Postby cougar » Sun Jun 21, 2009 9:35 am
Above the filter is the fuel heater. There is an o-ring between the heater and the adapter. Sometimes when you change the filter, the stub unscrews completely or comes loose enough to cause it to leak. The fuel heater sometimes cracks and leaks also. Some people remove them all together, they come in handy in cold climates.
01 2500 "the work truck".
cougar
Postby mprmn08 » Mon Jun 22, 2009 3:48 pm
i just had the same issue with mine a few weeks ago when i changed my filter. it was the oring about the fuel heater as cougar said. put on a new one and its perfectly dry now.
mprmn08
Postby Diezeldriver » Sun Jun 28, 2009 3:23 pm
Anyone have a part number?
Diezeldriver
Postby Greenleaf » Mon Jun 29, 2009 4:22 am
They are getting tough to find. It took me some doing, but in time I scored several. I don't use these as my filter assy is different on my trucks. If you do have to locate one here be the nos.
Mopar 04429695
Fleetguard (Cummins filters) 3834185-S
Greenleaf
tech specialist/mod
Heater O-Ring
Postby Featherman » Sat Oct 17, 2009 2:49 pm
How difficult is it to change the O-ring. I noticed a leak up around the fuel filter and am assuming its not from the fuel filter because its tight.
I am changing the filter again and figure I might as well chnage the heater o-ring while I'm in there.
Thanks,
Featherman
Postby mprmn08 » Sun Oct 18, 2009 9:47 am
its very easy. you take the filter off and then take off the stud that the filter screws onto and the fuel heater drops off and you take the oring off and put the new one on and do the reverse.
mprmn08
