idle too high
idle too high
Postby Firstgen1 » Sat Jul 11, 2009 1:47 pm
how do i adjust the idle lower when the throttle arm isnt touching the idle screw??
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby Ace » Sat Jul 11, 2009 2:26 pm
Is there any slack in the connection? If not, try expanding the turnbuckle connecting the throttle lever to the accelerator cable. Otherwise, turn out the fuel screw or reindex the throttle shaft.
Postby Firstgen1 » Sat Jul 11, 2009 5:33 pm
i got it, i was messin around with it and it like broke loose i think it was just hangin up and i didnt look good enough
Firstgen1
Postby JQmile » Sun Jul 12, 2009 12:50 am
Some people start grinding at the linkage to get the idle down with the fuel screw way up. I think I'm about there.
JQmile
Postby jbaker » Sun Jul 12, 2009 3:57 pm
another way to get really low idle is to use pliers on the cast ear that bumpstops on low idle screw then use linkage to set idle
learned this by accident the cast ear did not bend like i wanted it to duhh
93' w350 extended cab drw getrag, pump turned up and twisted, skirted flatbed
93 w350 extended cab drw auto, flatbed
jbaker
Users browsing this forum: No registered users and 123 guests
