lift pump part #
lift pump part #
Postby Firstgen1 » Sat Jul 11, 2009 5:35 pm
does any body know the new numbers to do a piston lift pump conversion
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby GPSMatt » Mon Jul 13, 2009 12:15 am
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby PToombs » Mon Jul 13, 2009 6:16 pm
Doesn't anybody use the search function? :roll: All that info is right here, no need to send him off site for it. Especially to that den of trolls! :shock:
Postby Tacoclaw » Tue Jul 14, 2009 6:09 am
Now now, we all know the search function won't work all the back to the 4th page :P
http://www.1stgen.org/viewtopic.php?t=4464 ;)
In all fairness, some of those numbers have been changed/updated, but they crossed them over with no problems for me. Also, if you don't bother reading past the first post in that thread, the Case price has doubled if I remember right. It may still be worth it to check it out, but Cummins ended up being cheaper for me.
Postby Firstgen1 » Tue Jul 14, 2009 7:16 am
thanks guys, the case price around here is still 148 dollars
Firstgen1
Postby Firstgen1 » Tue Jul 14, 2009 10:12 am
where does evryone get there conversion parts, the cummins and case dealer or is there a website that sells the parts?
thanks
Firstgen1
Postby PToombs » Tue Jul 14, 2009 6:11 pm
Either Cummins or the Case dealer. If you use the Case dealer, change the 1st digit, the "3", to a "J". I haven't checked lately to see if there are still any original pumps left. When they're gone, it'll be the $350 new ones. Kinda crappy, but what can you do? :cry: For that price, might better go with an AirDog or something for $150 more.
Postby Ace » Wed Jul 15, 2009 6:31 am
They are still available on the big auction site. I posted a link to one the other day over at the "den of trolls." :)
Postby PToombs » Wed Jul 15, 2009 6:19 pm
Ace, I can't help the "den of trolls" thing. I know some of you guys are on there, and I was referring to management. ;) You know how it is. :lol:
Postby Ace » Thu Jul 16, 2009 4:58 am
No problemo. I frequent all sorts of online troll dens. Fun stuff. 8)
Postby PToombs » Thu Jul 16, 2009 6:24 pm
:lol: :lol:
Postby Firstgen1 » Fri Jul 17, 2009 11:05 am
i was wondering what you use to cut the insulation with
Firstgen1
Postby Ace » Fri Jul 17, 2009 2:18 pm
I used a boxcutter. It's soft. I wouldn't try going in there with any power tools, because the fuel return goes through there somewhere and it's pretty hard to get at and see what you're doing.
Postby Begle1 » Fri Jul 17, 2009 4:13 pm
Don Tanklage had the right idea about going to a shorter fitting coming out of the top of the pump in order to avoid cutting the insulation. I felt stupid for not thinking about doing that myself.
I now apologize for saying that Don Tanklage had a good idea.
Postby PToombs » Fri Jul 17, 2009 6:18 pm
I used a 4" grinder with a cutting wheel on it. When I saw sparks I backed off a little. I didn't know I could use a utility knife on it. It's like a light plastic material.
