cams
cams
Postby Firstgen1 » Mon Jul 13, 2009 3:39 pm
is a cam from pdr diesel worth the money, how much power do the give you
thanks
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby dpuckett » Tue Jul 14, 2009 6:21 pm
I dont know if they give you any power as much as they give you better air flow, allowing you to add fuel and thus, more air to make more power.
Daniel
Postby mprmn08 » Tue Jul 14, 2009 6:59 pm
i can tell you we put a stock head on the flow bench at work and nothing over stock lift increases air flow on a STOCK head. so if its not ported i would say no. it will give you quicker spool so power will come on sooner but flow went down over stock lift. again on a STOCK head unported
mprmn08
Postby SNOOT » Tue Jul 14, 2009 9:44 pm
Pretty much what mprmn08 says you will get quicker spool your drive pressures will increase as well. They are keeping the exhaust valve open longer in most case to add more flow to the turbo.
Your truck will run cleaner and you may be able to run a larger turbo.
I am in the process of working out drive pressure issues right now but the truck picked up .60 in the 1/4 mile and it was much hotter out then my last run.
The truck runs much cleaner off idle then it ever did turbo lights almost right away.
1993 W350
SNOOT
