388 gov spring?
388 gov spring?
Postby dpuckett » Sun Jul 19, 2009 3:05 pm
It's not a typo- I have a 388 spring that came in the pump in my W350. It had been rebuilt once before I got it, and when I swapped tops a while back, I just put the spring and the whole shebang from the old pump on the "new" pump. I noticed that the number on the spring looked an awful lot like a "388" but thought it WAS kinda faded, and could well have been a 386. But, today, I resealed the top for the "new" pump, and put it back on, and compared the springs, and the 388 is about 2-3 coils shorter. Anyone have any clue what application it is from?
With the fuel screws within 1/2turn of one another between the 2 tops, I can go 31mph in 2nd w/ the 388; about 25mph w/ the 386- a 20% difference in RPM. The 388 seems to split the difference between the 366 (3200) and the 386 (stock).
I put the (stock) 386 spring in, and for the purposes of trying to eek every mile from a gallon of fuel, I am going back to 100% bone stock settings for a reference/ starting point :puker: . My green truck never got 20+ mpg after I installed the 366 spring, and I have a feeling the springs may affect the MPGs in some cases. And it may not....
Dan
Postby Oddfire » Sun Jul 19, 2009 5:10 pm
I have a VE off of a skidder next to my tool box at work that has the same spring in it. ;)
Oddfire
Postby bgilbert » Sun Jul 19, 2009 5:36 pm
It's just a stock Dodge or actually Bosch spring. 386 and 388 are both found in our trucks. I would guess cpl or model year might determine which spring the pump got.
Bill Gilbert
Postby gear jammer 91" » Sun Jul 19, 2009 9:06 pm
My non-intercooled pump had the 388 spring in it. I can't remember if my brothers intercooled truck had the 388 or not.
01 LB7
gear jammer 91"
Postby dpuckett » Mon Jul 20, 2009 9:18 am
The differences in the springs would explain how some guys can reach 3000 pretty easy, and others struggle past 2500.
Postby GO OVRIT » Mon Jul 20, 2009 2:53 pm
My intercooled trucks have all had 386's but RSWORDS non-intercooled truck had a 388.
GO OVRIT
Postby Begle1 » Mon Jul 20, 2009 2:56 pm
So what's better, the 386 or 388?
Maybe I had the better of the two and that's why I hardly noticed anything with my 3200 RPM spring.
Postby gear jammer 91" » Mon Jul 20, 2009 6:00 pm
Now I'm all confused, I just found what I think is the stock governor spring from my truck and it say' 386 :? . I've done two gov springs, one in my non-intercooled truck, and one in my bro's intercooled truck. I don't know for sure which truck the spring I found came out of. When I put the 366 spring in my truck , I noticed a hug difference, my brother didn't seem to notice as much of a difference as I did.
01 LB7
gear jammer 91"
Postby dpuckett » Tue Jul 21, 2009 3:21 pm
I'd venture to say the 388 is a higher RPM spring than the 386- it is shorter. With the 386, I have slightly less top end in each gear- 45mph is about it in 3rd now, vs 50 coming easy with pedal left over with the 388.
Daniel
Postby 90FIRSTGEN CUMMINS » Tue Jul 21, 2009 7:54 pm
I did my gov spring not all that long ago and my truck had a 386 spring. My truck is a non intercooled 1990.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
