Freeze plug
Freeze plug
Postby noseamum » Fri Jul 24, 2009 7:56 am
The freezeplug on the back of the engine decided he didn`t wan`t to be part of the fun anymore and left the building.
So I ordered a bolt in rear freezeplug from www.puredieselperformance.com but do anyone know if I will need the others strenghtened as well??
Max rpm is 3600.
And is anyone running the electric water pump?
1990 W250 2gen IC,HX35,727trans 3.07,35"BFGs.225RWHP
noseamum
Postby noseamum » Thu Aug 06, 2009 8:08 am
Got the part now and decided that I might mount a regulator bypass system, but searched and didn`t find any info on how much pressure and where to fit it.
I was thinking an elbow in the back that has a pressure valve that opens for flow at 28psi and just send it into the return line from the cab heater with a T joint.
But any advice or links on how to would be appreciated.
noseamum
Postby Ace » Thu Aug 06, 2009 8:38 am
it doens't need to be that complicated with a regulator or anything and it's a good idea to put a bypass in there as long as you're at it anyway. I would use maybe an 1/8" restrictor in the fitting and run your line to a return like you said or maybe a trans exchanger line if you have an automatic. This will help cool the back of the block better at all times instead of just some arbitrarily regulated pressure point.
Postby noseamum » Thu Aug 06, 2009 2:44 pm
Yes that makes sence, keeping it constant and simple :D Thanks.
noseamum
