Hi guys, I've got a 1989 4x4. Installed a 3200 spring yesterday and everything went pretty smooth. Got the truck all put back together, fired it up and no visible problems. I let it sit there and idle for a few minutes and it ran great. Got in it and hit the throttle and it died. I thought that was strange so I started it back up, fired right up again, eased on the throttle and the rpms slowed down until it cut off. As far as I can tell from idle, the more throttle I give it, the slower the rpms get until it cuts off. It almost acts like the throttle is acting in reverse. Could I have have indexed the throttle shaft wrong putting it back together and thats what causing this or could it be something else? RSWORDS sent me over here to ask he's a good friend of mine and he said you guys could probably help me out. Thanks in advance
Jason
