1st Gen Mud Truck
1st Gen Mud Truck
Postby MudSlinger79 » Fri Jan 02, 2009 12:42 pm
http://www.youtube.com/watch?v=0E36ZAmSM2Q
It not drivable yet but its on the way. It has a 93 12v, a 2wd nv4500, divorce mount dodge np 205 piggybacked with a 2 1/2 ton case, feeding 5 ton rockwell axles, connected to 63" rice and canes. The motor has new era 435's, 366 spring, pump cranked afc is mia and a HTTB S300 66/71 turbo wastegate set a 55lbs , head bolts removed oiled and torqued to 125. Its getting there just a lot of work.
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby Diesel Dan » Fri Jan 02, 2009 8:25 pm
:shock: :shock: Holy Frekin Crap :shock: :shock:
i like it
1992 cummins, 350, single cab, 8 foor bed (kinda), manual, 4x4
Right now Very ugly but its a cummins!
Diesel Dan
Postby dpuckett » Fri Jan 02, 2009 10:19 pm
I dont normally go for lifted insane stuff, but I like it, too.
You might want to consider some lift pump/ supply upgrades. Stock lift pump wont supply 435s with stock IP settings.
Daniel
Postby MudSlinger79 » Fri Jan 02, 2009 10:41 pm
I am planning on running a holley blue in tandem with the stock lift pump. Thanks for the complents on my truck. I can't wait till I can drive it and throw some black smoke.
MudSlinger79
Postby 75Dodge » Sat Jan 03, 2009 5:24 pm
That's just bitchin'! WOW! where did you get those axles?
1989 D-250 LE Automatic 150hp at 55mph! 3200K Spring, tweaked pump, H1C/H1E hybrid.
75Dodge
Postby MudSlinger79 » Sun Jan 04, 2009 3:59 pm
I got them from a place in lufkin tx.
MudSlinger79
Postby 92 cummins » Sun Jul 26, 2009 8:52 am
thats coooool. 8)
92'W250,bullydog fuel pin,6in skyjacker with Mickey Thompson bead locks 16x12, 35's, custom 4in exhaust, K&N intake. 80k miles.
92 cummins
Postby Bad93Cummins » Sun Jul 26, 2009 1:51 pm
Been watching truck on chucks trucks, awesome truck and great cummins conversion!
Bad93Cummins
Postby MudSlinger79 » Tue Jul 28, 2009 6:15 pm
Thanks yeah im pulling everything off the chevy and putting it in a 93 ford 4 door. Its time to ride on a 4 link and ac.
MudSlinger79
Postby MudSlinger79 » Tue Jul 28, 2009 6:22 pm
MudSlinger79
Postby Bad93Cummins » Wed Jul 29, 2009 8:09 am
You still keeping the cummins motor?
Bad93Cummins
Postby MudSlinger79 » Wed Jul 29, 2009 1:07 pm
Oh yeah cummins all the way
MudSlinger79
Postby JQmile » Wed Jul 29, 2009 6:27 pm
Don't use the holley blue in tandem, the stock lp will just be a restriction. Also get a filter off of a bigger industrial engine or something, the stock filter only flows about half of what the holley can put out.
JQmile
