Non/ic 9mm 5 hole school bus injectors ???
Postby oldcool90 » Sat Aug 01, 2009 7:31 pm
They are a 5 hole injector, look's to be close to the same size hole's that are in my stocker's just an extra hole.Has any one ever messed with these.My friend say's that the bus motors are rated at 180hp,just wonder'n what the hole size is on these injector's are.
oldcool90
Re: Non/ic 9mm 5 hole school bus injectors ???
Postby RSWORDS » Sun Aug 02, 2009 7:51 am
oldcool90 wrote:They are a 5 hole injector, look's to be close to the same size hole's that are in my stocker's just an extra hole.Has any one ever messed with these.My friend say's that the bus motors are rated at 180hp,just wonder'n what the hole size is on these injector's are.
Are tehre any numbers on teh injectors?
RSWORDS
Postby gear jammer 91" » Sun Aug 02, 2009 10:47 am
If nobody knows try an injector shop around your area.
01 LB7
gear jammer 91"
Postby dpuckett » Mon Aug 03, 2009 9:00 am
You can remove the tip from the injector and it will have some numbers stamped on it under where the body covers it up.
DP
Postby bgilbert » Mon Aug 03, 2009 9:44 am
I don't think there were any visible numbers on the nozzles when Matt had them apart. I remember Greenleaf ran a set of these in his nonIC'd truck. I would guess a +20hp gain :P - 180hp > 160hp...
Now Matt you weren't supposed to tell anyone about these until after Dunbar's dyno at Scheid's event 8) . You were supposed to show the internet folk that 400rwhp was/is possible with stock injectors, fuel only of course. :lol:
Bill Gilbert
Postby peytonmaterne » Sun Aug 09, 2009 11:39 am
Interested in the specs on these, have you found out any more about them yet?
91.5, D250, getrag
91.5, D250, auto
84, D150 with 90 dodge/cummins drivetrain
peytonmaterne
Postby Crazy Matt » Sun Sep 06, 2009 2:59 pm
A cpl # might be handy to do some more finding on them
'90 cummins, mod'd 727,converter ,4" from dp back, 16cm,ported exhaust housing/ats manifold, gds 60mm upgrade, 366, dennyt pin, .Ported head, camshaft. In the process of resetting injector pop pressures and put the whole mess back in the truck.
Crazy Matt
