366 what did i screw up???
Postby Mike6bt » Sun Aug 02, 2009 11:59 am
Ok , i gots me a 91 non i/c auto with some pump tweaks
i recently installed the 366 spring and while i was there i bumped the timing on it. Upon fire up it would idle real high but when i put it in gear it would lug down and wanna snuff out :shock:
so i brought the timing back, and played with the fuel screw and got the ol girl to hold her own in gear but the idle is still wayy to high ???
If anyone can help it would be appreciated.
91 3/4
-straight pipe
-no i/c
-slightly massaged pump
Mike6bt
366 Spring mod
Postby SmokeScreen » Sun Aug 02, 2009 1:09 pm
I had the same problem, when I put mine in. I just adjusted the lever on the front of the IP. It's kind of a pain, but it helped alot and then I fine tuned it with the linkage adjustment.
SmokeScreen
366 Spring
Postby SmokeScreen » Sun Aug 02, 2009 1:18 pm
May as well turn your fuel pin around while your at it
93 CTD, Ground pin, 3200 Spring, fuel screw all in, 05 Holset 3, Cooler Tubz, 4" straight pipe & stack, Industrial Injection injectors, fuel pickup mod & 1/2" lines, lift pump, 4" Skyjacker w/35" Claws 1st at Sublimity Harvest Festival
SmokeScreen
Postby dieseljack » Mon Aug 03, 2009 8:41 am
Don't spin it take the grinder to it remember nice and slow trust me
1991 w250 rebuilt auto 170xxx Straight 4" turbo back dennyt stage2 fuel pin pump turned up 1/4 from bad new era 370s
dieseljack
Postby Mike6bt » Mon Aug 03, 2009 4:14 pm
awsome man, turns out I had the lever off by one notch got her all dialed in and runnin prime. makes the in town drivin a bit better not idle'n round 1100 lol
thanks smoke
Mike6bt
Postby SmokeScreen » Tue Aug 04, 2009 12:18 pm
No prob man, a little friendly advice goes a long way. That's how i've gotten all my stuff done, just by askin' questions.
SmokeScreen
