4200 spring
4200 spring
Postby boostedve » Thu Jul 30, 2009 4:00 pm
im putting the 4200 spring in my 93 d250 im putting new valve spring in and im just woundering if i should upgrade the return springs in the pump.. i think thats what they are.. if so does anyone have the part number for them..
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby peobryant » Sat Aug 08, 2009 4:33 am
Why are you going to a 4200 RPM spring? There is really no need for it, as the VE doesn't really make power over 3K anyways.
A sledpuller would be the only case I could see a VE needing a 4200 RPM spring.
Postby seeker1056 » Sat Aug 08, 2009 5:52 am
I beg to differ - my truck makes awesum power over 3000 rpm, matter of fact it pulls like a frieght train all the way to 3600 rpm in second gear and to 4600 rpm in 1st gear
the 4200 rpm spring is definitely a worthwhile mod if you have the motor to back it up
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby mprmn08 » Sat Aug 08, 2009 9:01 am
uh dont you have a very well worked over pump though? as far as a stock pump is there really a need for it?
mprmn08
Postby RSWORDS » Sat Aug 08, 2009 9:31 am
mprmn08 wrote:uh dont you have a very well worked over pump though? as far as a stock pump is there really a need for it?
On a stock pump.. No way.
RSWORDS
Postby peobryant » Sat Aug 08, 2009 11:38 am
seeker1056 wrote:I beg to differ - my truck makes awesum power over 3000 rpm, matter of fact it pulls like a frieght train all the way to 3600 rpm in second gear and to 4600 rpm in 1st gear
Isn't your truck primarily a sledpuller? That's what I said in my post, I could see the 4200 RPM spring being useful in a sledpulling application, but not much else.
His being a 2wd dually, I don't think he'll be hooked to a sled very often. :D
By the way, I enjoy watching your truck pull, (on YouTube) it's cool to see a competitive VE.
