holy shiste!
Postby roxxx » Fri Aug 07, 2009 10:18 pm
I was told by a crusty old Finning Mech that every oil change inspect your blades heck the DODGE techs are supposed to do IT . ..... lol Considering i caught it on my 2001. had turbo failure they were HUH . One more thing that old crusty dude said DO NOT touch YOUR BLADES with your grease fingers . He said the minute partials can throw the turbo out of balance and cause premature failure
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby 1991cummins » Sat Aug 08, 2009 12:11 pm
well i need to contact pdr or something then, cause that turbo should not pop that soon... i think its ok though... has anybody ever had a gasket go out on they're intake horn? right above or below the grid heater?
1991cummins
Postby fergavs » Sat Aug 08, 2009 2:39 pm
Ya I had to replace that gasket before and Ive heard of a few others doing the same.
fergavs
