Cooler tubz
Cooler tubz
Postby TTipswprd » Sat Aug 15, 2009 2:20 pm
What are the gains in this product? (egts, power, boost, ...) Is it worth the money?
1992 w250 4x4, pump tuned, custom exhaust, intake, and dennyT fuel pin, cooler tubz, 5x.014's from SDX
TTipswprd
Postby peobryant » Sat Aug 15, 2009 2:24 pm
Lower EGT's, less restriction, and it looks DAMN good. 8)
Postby peobryant » Sat Aug 15, 2009 2:29 pm
I can't tell you if they are worth the money... yet. :D
Postby TTipswprd » Sat Aug 15, 2009 4:14 pm
they do look good but i prefer function over fancy :lol:
TTipswprd
Postby peobryant » Sat Aug 15, 2009 6:14 pm
TTipswprd wrote:they do look good but i prefer function over fancy :lol:
The last picture I posted is the stock 1st Gen airhorn (left) versus the Coolertubz. Which one would you rather have? ;)
I believe it was Philip that said a 24 Valve airhorn will get you the same EGT reduction as a set of Coolertubz.
You could always PM TWorline on here. He is the guy who makes and sells Coolertubz, and he'll be happy to answer all your questions. 8)
Postby TTipswprd » Sat Aug 15, 2009 6:33 pm
oh i see that comparison should have much more air flow with the cooler tubz. ill message him thanks for all the help!
TTipswprd
Postby Philip » Sat Aug 15, 2009 6:44 pm
I have ran a set of cooltubz's and a 24 valve air horn on a dyno. Both made the same numbers. I depends on what you want the engine compartment to look like. Stealth stye with a 24 valve air horn or modded look of the cooltubz's. Eather way gets the job done better than the stock air horn and IC tubes. :D
Postby TTipswprd » Sat Aug 15, 2009 6:50 pm
ha ha well most people could care less about whats under my hood by the way the outside looks. kinda funny the looks i get from drivers when i smoke out an intersection. even from other diesel drivers. guess i just aint got a typical diesel truck out here in Wyoming! does the second gen intake horn use the same size gasket and does it line up like stock?
TTipswprd
Postby Philip » Sat Aug 15, 2009 7:44 pm
All cummins air horns and grid heaters take the same gaskets. It doen't matter what the year is.
You would need the left side IC tube made. Tim has the pattern for it. Use the 2nd gen 24 valve air horn. It doesn't have the big wing on it like the 12 valve does.
Do Not use a 3rd gen air horn. It isn't any better than the 1st gen air horn is.
Postby TTipswprd » Sat Aug 15, 2009 7:50 pm
thanks for the info. now i need to figure out my next upgrade will be....
TTipswprd
Postby Oddfire » Sat Aug 15, 2009 8:34 pm
I did a mid section cut-down on a 3rd gen intake horn and a 98 12 valve horn. At the outside 2 bolts where the horn starts to make the 90 degree turn down into the head, the 12 valve horn is over a square inch in volume area larger :D (1.27...er somethin like that).
I should have taken photos.... :;-|:
Oddfire
cooltubz
Postby loco one » Sun Aug 16, 2009 8:22 am
I"m Getting a set (cooltubz ) I want my EGT lower ! It"s gotta help ,I"m somewhat on the fence on which one ? I"m thinking I want to eliminate my intake heater ? ( live in california ) Why not ? my 2 cents ! :? :? :?
Locomotive one ,92,cc,le,4x4,nv4500,KDP,oldsmokee power pin, pac ,brake,14w/g,some pump tweeks,
loco one
Postby DennyT » Sun Aug 16, 2009 10:30 am
Go with the Tubz. Great guy, Great product! TWorline is one of the few here for 1st gen support which is a dieing trade these days..........
1992 Cummins Ext Cab 4x4 NV4500
DennyT
smoke screw?
Postby Oddfire » Sun Aug 16, 2009 10:43 am
Howdy Denny! ;)
:lol: :lol: :lol: :lol:
Oddfire
Postby TTipswprd » Sun Aug 16, 2009 11:03 am
Thanks for the input Denny. How much does this kit cost as i cannot get ahold of the man.
TTipswprd
