changing housing
changing housing
Postby T.winegar » Sun Aug 16, 2009 5:20 pm
looking to change my exhaust housing from the 18 to the 16cm.
what is the best route of doing this? I don't think its too hard, but most of you know more than I do.
any with experience please give me tips. I've had enough mess-ups on this truck, so I would like doing this simply and once.
thanks
89 727-stageIvcomp 4in intake-amsoil air filter, 4in exhaust, dennyT, 366 spring. pump turned up to make me smile! low stall converter, rebuilt tranny at 120,000miles
T.winegar
Postby Richie O » Sun Aug 16, 2009 5:31 pm
My advice is put PB Blaster on it every day for a week. Be prepared for a fight.
Postby cougar » Mon Aug 17, 2009 8:32 am
Remove the oil supply line and give it a good flushing with some carb cleaner. Also use ant-seize, the high temp stuff on the bolts when you put it back together.
If you haven't yet, while it is off would be a good time to drill and tap your exhaust manifold for an EGT probe. You don't want metal getting into your engine or turbo. Stick a vacuum in there while you drill and tap.
01 2500 "the work truck".
cougar
